Matt Jesty
- May 15, 2002
Q150e from Rel offers many advantages, mostly in terms of how it connects and the seemles integration with music .I am curious if there are any other suggestions under $1,200?
Sporting the same custom EQ as used in the base Rava, this amp includes a true 4th order Linkwitz Riley crossover with independently adjustable low pass AND high pass settings (line level outputs only). Add in a quasi-parametric EQ and completely balanced circuitry, and the Rava SE is suited for nearly any audiophile systemThe eq is a rumble filter with a corner frequency of 18hz that provides 1dB of boost at 25hz.
Another option would be to get Acoustic Visions to build you a low Q sealed Tempest/Dayton DVC15" (enclosure might be a little bigger than you would like, around 200L) or a Dayton Titanic MKII (around 100L enclosure would be required) powered by the HS500. These options would get up around $1000 though. You can get really nice veneer vinishes from Acoustic Visions as well for a few $100 extra.
