killercuda
- Aug 12, 2006
- randi
another novice here and any help would be greatly appreciated! i would like to know if some people could tell me how to connect my system " optimally "? i dont have the manuals because these components were given to me . i have the following : a standard cable box with composite out , digital audio out (rca) s-video ,ir, usb port . the television is a toshiba 32AF45 with colorstream it has 3 composite video imputs , 1 s-video imput and 1 component video imput the dvd player has 1 composite out , 1 s-video out , 1 component video out , and 1 digital audio out (coaxial) the vcr has just 2 composite , 1 in 1 out . now for me ,the chaos begins ! the HT Receiver is a pioneer VSX-9300TX . to me this seems to have alot of options for hook-ups . i don't want to give the specs for fear of messing it up . i'm sure atleast someone here is familiar with this receiver , and could tell me how to "optimally" apply my other components . i was told it was a decent receiver . please , any help would be greatly appreciated , thanx Type Receiver
Number of Channels 7.1 Channels
Stereo Mode Power 110 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.09%
Surround Mode Power 110 Watt @ 8 ohm, 20 Hz - 20 kHz, THD: 0.09%
Surround Sound DTS ES® • THX EX® • Dolby Pro Logic II • DTS Neo:6 • DTS 96/24
THX Certification Select
Inputs / Outputs
Rear Input Connectors RCA (2 Audio Channels) x 9 • Digital Coaxial x 2 • Digital Optical x 3 • S-Video x 5 • Component x 2
PC Interface USB
Surround Analog Inputs 7.1 Channels x 1
Preamp Outputs 7.1 Channels
Convenience
Tuner Presets 30 Channels
On Screen Display With OSD
Remote Control
Remote Control Type Learning
Illuminated Remote Illuminated
Design Keypad with Display
Dimensions
Weight 45 lb.
Miscellaneous
MPN VSX9300TX
Product ID 24968659
Inputs / Outputs
PC Interface USB
Convenience
Remote Control
Dimensions
Weight 45 lb.
Miscellaneous
MPN VSX9300TX
Product ID 24968659
