Small 480p TV?
Discussion in 'Archived Threads 2001-2004' started by Anthony_ F, Sep 22, 2001.
  1. Anthony_ F
    Anthony_ F Auditioning
    Mar 25, 2000
    I am looking for a small 480p capable television (20-32 inch or so). Does anyone know of any good ones? The tv will be used for DVD and Nintendo Gamcube(it supports 480p natively) in a dorm like environment so the tv can't be that large (hence the 20-32 inch requirement). Thank you very much for your help!
  2. Jack Briggs
    Jun 3, 1999
    16,738
    129
    What does your budget allow for? Philips markets a 30-inch 16:9 direct-view set that has earned some rave reviews. And, of course, it's 480p-capable.
    You might also consider Sony's 4:3 KV-32XBR450 (which has a raster-collapse function to produce a true 16:9 "window"). Finally, there's an $1800 (msrp) 32-inch Panny that can do 480p (though, in my view, Panasonics tends to have too much of a blue-ish cast, even at the lowest temp setting).
    [​IMG]
  3. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    I believe Samsung might have what you're looking for. Sorry, I don't have any specific model numbers for you though.
    John Golitsis
    Next Big Thing Electronics
  4. CarlS
    CarlS Stunt Coordinator
    Aug 15, 2000
    83
