Slight hum
Discussion in 'Archived Threads 2001-2004' started by Vlad D, Jun 21, 2002.
  1. Vlad D
    Vlad D Screenwriter
    Oct 24, 2001
    1,076
    Vladimir Derenoncourt
    I hear a slight hum in my speakers when I have my amp and receiver (which I'm using as a pre/pro) turned on but no music playing. When I used the receiver without the amp and had nothing playing, I did not hear a hum. Is this normal?
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    I don't know if it's normal, but it seems quite common.
    The way to find out what is causing it is to sequentially disconnect items until the hum goes away. Then at least you can isolate it and determine if it is a problem that can easily be solved.
    See this thread also:
    http://www.hometheaterforum.com/htfo...&highlight=hum
  3. Vlad D
    Vlad D Screenwriter
    Oct 24, 2001
    1,076
    Thanks John. I read the other thread, and the thread starter has a Denon same as I do. I wonder if this is a problem with Denons? I posted to the other thread to see if he ever solved his problem.
