Sleeves for Flexi-Rack support rods?
Discussion in 'Archived Threads 2001-2004' started by GarryW, Oct 15, 2001.
  1. GarryW
    GarryW Stunt Coordinator
    Jun 27, 1999
    162
    I am thinking about building my own flexi-rack but don't care for the exposed threaded rod look. Has anyone built one with some type of tube material to cover this up?
  2. Jim Robbins
    Jim Robbins Stunt Coordinator
    Sep 3, 1998
    233
    I used 1" ID PVC pipe sprayed gold. I used 1" washers to lock the pipe in place.
  3. GregE
    GregE Agent
    May 24, 1999
    25
    I used 1 1/4" conduit sprayed black. I didn't care for the flimsy feel of PVC and wanted added strength. The washers for the 3/4" threaded rod are large enough that the conduit rests on them. The condiut give it a nice solid feel. My flexy entertainment center could withstand a tornado it feels that sturdy and heavy.
  4. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,749
    480
    9,110
  5. Robin Smith
    Robin Smith Stunt Coordinator
    Sep 27, 2000
    184
    One look that I thought of but never tried is to use lengths of heatshrink tubing. This is the stuff normally used to add strength to cables where they meet connectors. You can get it in various thicknesses. Simply slide pices of the unshrunk tube of the rods, assemble your rack and then finish off with the hairdryer to tighten the shrink tubing to the rod. Should be a pretty slick look.
    Here is a PE link to an example of it in a one inch thickness (shrinks to as much as 1/2 inch).
    http://www.partsexpress.com/pe/showd..._ID=2039&DID=7
    The product picture is blue, but it available in lots of colours including black.
    Robin Smith
  6. GarryW
    Jun 27, 1999
    162
    Great ideas! Have another question:
    I notice that Lovan makes their racks in a 3 post design, with 2 post in the front, and one in the back center. It's a sharp design, but one of the reasons I'm going to an open rack design from a closed cabinet is to be free from obstructions. Has anyone made their flex-rack this way? [​IMG]
  7. Jason Watson
    Jason Watson Stunt Coordinator
    Sep 10, 1999
    139
    Click on the home icon to see my quasi-flexi design using black painted conduit as sleeves. The pics are very out of date but I still use the rack.
    Jason
  8. Brian Schucher
    Brian Schucher Supporting Actor
    Nov 22, 2000
    700
    Believe it or not i used black split loom tubing. It doesnt cover the large nuts but covers most of the threaded rod and the only exposed areas face the back of the rack.. I think it looks excellent. Its easy and cheap to change sizes if you adjust your shelves later too. Just re-trim the tubing..
