Size of a 24 inch tube & a 27 inch tube? (1 Viewer)
Jason GT
Pythagoras should be your friend.
It's a bit easier since you can work things out as a 3/4/5 triangle.
a 27" _tube_ should be about 20.8" * 15.6". Add a bit for the frame and outside of the set.
a 24" _tube_ should be about 19.2" * 14.4".
An entire television set will be bigger.
Larsenv
