CurryFiend
- Nov 25, 2017
- Edward
Hi,
I've just converted my garage into living space and would like to set up a home cinema system with a projector.
Sadly, the construction work has really hit me hard in the bank account and so I'm trying to find a way to achieve my aim by using what I've got and/or keeping expenditure down.
What I'd like to do is take four feeds (digital tv box, PS4, satellite tv, desktop computer, all of which are HDMI feeds) into a projector for the visual part and maybe use the existing sound bar (which I bought with my tv) for the sound.
I understand that usually with a projector, the feeds will be taken to an AV receiver which then sends out a signal to the projector and the sound out to 6 or 7 speakers and a subwoofer. To be honest, I can't be bothered with all of the cables and hassle attached to that many speakers, so I think the sound bar solution will work best for me.
So my question is: Is there a box equivalent to an AV receiver that will take my four feeds and split the signal for the projector and the sound bar?
Also, I need to get the HDMI signal from the box to the projector, but I haven't buried any cables in the wall to do this. I'm thinking about using one of these:
https://www.amazon.co.uk/s/?ie=UTF8...d=kwd-305283861791&ref=pd_sl_1d6b9o9gg8_e_p28
So far, my costs are: projector (est.), £600, transmitter/receiver, £200, AV receiver or equivalent box, not sure.
Am I missing anything obvious?
Thanks in advance for any help offered.
Curry Fiend
Curry Fiend
