silly question but......
Discussion in 'Archived Threads 2001-2004' started by harvey_mason, Oct 15, 2002.
  1. harvey_mason
    harvey_mason Agent
    Sep 14, 2002
    33
    I just got my mits 65611 and love it...
    my question is now that I do not have a vcr hooked up to my ht. system how can I get my cable tv to come through my main speakers and not just my tv speakers...
    I have a nakamichi av-10 receiver. DO I just run the cable coax into my receiver? Isn't there something else I need to do?? Right now it is plugged directly into the television.
    Secondly, will I lose any picture quality if I go into the receiver???
    Thank you and please excuse my ignorance..
    regards,
    harvey
  2. Jeff Braddock
    Jeff Braddock Second Unit
    Jan 26, 2002
    306
    If your tv has an audio out, hook that to the receiver.
  3. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    ... by the use of RCA cables L & R.
  4. Robert_J
    Robert_J Lead Actor
    Aug 22, 2000
    8,288
    51
    Mississippi
    Looking at the specs of your TV, you have both analog and digital audio outputs. There should be a menu option to toggle the analog audio between fixed and variable (at least I've seen it on my 55411). I don't know about the digital out. It may only work when viewing an HD program or it may work for both HD and SD programs.
    Your receiver does not have a TV tuner built in. Connecting your cable to it will do nothing.
    -Robert
  5. harvey_mason
    harvey_mason Agent
    Sep 14, 2002
    33
    so I go cable coax into the tv and video out into aux in in my nakamichi???
    IS this correct???
    thanks,
  6. Yee-Ming
    Yee-Ming Producer
    Apr 4, 2002
    4,368
    14
    "on a little street in Singapore"
    Yee Ming Lim
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    think of it this way harvey.
    you need to get the sound from the tv to the receiver right? so, you need to send the sound out from the tv into the receiver.
    you do this using the audio out (red & white plugs) from the tv to the receiver's audio in.
    tv audio out --> receiver audio in
    you can choose whatever input on the receiver you'd like (video1, video2, etc.)
    the difference between fixed and variable output (on the tv) is that the variable option will allow you to control the volume via the tv's remove. fixed will force you to use the receiver's volume control.
  8. harvey_mason
    harvey_mason Agent
    Sep 14, 2002
    33
    Thanks alot Ted..
    That information was very helpful and informative..
    I did it last night and it worked perfect!!
    regards,
    harvey
  9. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    glad it worked harvey! congrats! [​IMG]
