Silly question about a DIY sub
Discussion in 'Archived Threads 2001-2004' started by tom_furman, Jul 31, 2002.
  1. tom_furman
    tom_furman Stunt Coordinator
    Sep 6, 2000
    174
    I looked over Patman's DIY sub page and found it very useful. He did not want to mount his amp directly to the sub. If i build one, like to mount my amp to the sub. Where/how would I go about doing that? I havent seen any pics of a DIY sub with the amp attached.
  2. Darren_T
    Darren_T Second Unit
    Oct 1, 2001
    494
    I just finished mine and it's easy. You need to use a plate amp first off. When you get the amp just measure the clearance and cut a hole for it. I used T-Nuts and hex head bolts to fasten mine but you can just use pan head wood srews preferably black. The amps come with a closed cell foam seal already in place usually. The amp housing is sound and air tight.
    [​IMG]
    Darren
  3. tom_furman
    Sep 6, 2000
    174
    Thanks! So attaching an amp to sonotube would be impossible I assume. Where would you put your amp then? On the floor? Behind the sub?
  4. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    It is possible but very difficult. Several have done it but I have only seen one flushmounted to a sonotube. I don't remember who it was. There was pics though. Do a search and maybe you can find it.
  5. tom_furman
    Sep 6, 2000
    174
    Where do most sonotube people put their amp? just have it sit on their equipment rack?
  6. Darren_T
    Oct 1, 2001
    494
  7. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Thanks Darren. I wouldn't exactly call my method a flush mount. The advantage is it doesn't comprimise the integrity of the tube at all. Disadvantage is it makes it a little difficult to make the sock.
    Now, for a method (and an awesome job executing it) to flush mount an amp to a sonosub check Warrick's sub out:
    [​IMG]
    Lots of pictures and detail on how it was done here:
    http://members.optushome.com.au/wcallen/
  8. Darren_T
    Oct 1, 2001
    494
    Oooooohhhhh prettttty. I like that too. If I make a sonosub for the next house I'm gonna do that.
    Darren
  9. tom_furman
    Sep 6, 2000
    174
    Two more questions...
    1. the the design above...how exactly does that frame for the amp screw into the sonotube?
    2. is caulk really enough to hold the PVC port in place?
  10. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Well mine has screws going from the inside into the mounting frame which was also glued on.
    The true flush mount one does the same thing but in the opposite direction (plus glue and calking I'm sure).
    As for the port. I put a couple nails in mine along with glue and calking. But glue, if the port is held into position while the glue is allowed to dry properly would be plenty strong enough. The caulking is more to just make sure there are no air leaks. The only hole you want in the box is the port.
  11. tom_furman
    Sep 6, 2000
    174
    Thanks Darren! you're slowly educating me!
    last question for today...is there a list of "common" or "widely accepted" heights/diameters/port sizes to use with the 15" tempest and avs2500 amp?
    i'm open to any size really...height is not really an issue for me.
  12. Darren_T
    Oct 1, 2001
    494
    Well your welcome.....but I think you meant Dustin for this post [​IMG]
    I'll take the thanks anyway though. I'll share with ya Dustin.
    Darren
  13. warrick
    warrick Stunt Coordinator
    Jan 11, 2002
    75
    Thanks for the plug Guys
    Tom if you have any specific questions about my sub you can mail me at
    [email protected]
    Regards
    Warrick
  14. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Well you'll have to do the math on the tube sizes (V = Pi x R^2 x H). Just has to be big enough for the driver to fit and long enough for the port to fit.
    Head to Adires site and they have pdf files listing reference designs for the Shiva and Tempest.
    They also have a free download of LspCAD that works with their drivers. You can use this to calculate how long a port needs to be for the enclosure volume you choose. You can also look at WinISD Pro for this purpose. You'll need this if you plan on using a larger port, don't use a smaller one than recommended in the reference designs though.
  15. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    Dustin,
    I ain't sure what kinda math you guys have up there in Moose-screwin' country (we screw deer down here!) [​IMG] but I believe the volume of a cylinder would be (V=R^2 x Pi x H). I'm not sure where you got 2R^2 from! [​IMG]
    Brian
  16. tom_furman
    Sep 6, 2000
    174
    What diameters does sonotube come in? Anything a bit smaller than 24" that will fit a 15" driver?
  17. Mark Fitzsimmons
    Mark Fitzsimmons Supporting Actor
    Aug 18, 2001
    539
    Area of a circle is PiR^2
    Volume of a cylinder is PiR^2h
  18. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Hehe, oops. I confused the area and circumfrence formulas. I'll have to go edit that :p)
    Tom, it comes in 2" increments from less than 10" all the way up to over 40". I used 18" for my Tempest and I wouldn't go any smaller. Driver end cap would get too thin and it would be impossible to mount the legs on the bottom, you'd have to attach them to the side of the tube.
  19. Brian Bunge
    Sep 11, 2000
    3,716
    Dustin,
    What, no comment about "Moose-screwing country"? You're slippin' man! I guess the job search is getting to ya? [​IMG]
    Brian
  20. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Ya, I'm feeling sorry for myself in that reguard. But as for the moose comment, just letting you look like a fool. Moose screwing country is 5 hours to the east of me in Moose Jaw Saskatchewan. I'm in Saskatoon, all we got are kick ass berries [​IMG]
    Mmmm, Saskatoon berry pie. I gotta pick me up one of them [​IMG]
