Silicon Image chipset - Only in Denon?
Discussion in 'Archived Threads 2001-2004' started by WilliamB, Jan 4, 2002.
  1. WilliamB
    WilliamB Stunt Coordinator
    May 4, 2000
    60
    Howdy folks...
    I'm looking for a prog. scan player and based on advice posted here the Silicon Image chipset seems to be best. But, the wife has me on a budget ($400) and I've not found the Denon 2800 for less that $600. Is there another single disc player that uses this chipset or is there another solution within my price range? My 56X81 is BEGGING for prog. scan!!! [​IMG]
  2. Ron Alcasid
    Ron Alcasid Stunt Coordinator
    Apr 11, 2000
    168
    Any players with the Faroudja chip will be just as good and are probalby the only ones in your price range.
  3. Darryl_B
    Darryl_B Stunt Coordinator
    Mar 2, 2001
    66
    You might want to check out the Panasonic RP56. It has the Faroudja FLI2200 chipset, very comparable to the Si503. Can be had for around $230 and is the only player in your price range with one of the superior chipsets.
    DB[​IMG]
  4. WilliamB
    May 4, 2000
    60
    Thanks a lot. One other question:
    What chipset do the Toshiba prog. scan units use? Would you pick the Tosh. SD6200 for $350 or the Panny RP91 for $440 or the panny RP51 for a bit less?
    I'm really on the fence as my goal was the Denon 2800 but the wife won't fund that one... [​IMG]
  5. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    Based on shootout results, for progressive scan performance I would go with either the Panasonic RP-91 or the RP-56 over the Toshiba unit (chroma bug and Genesis chipset).
    THe RP-91 has a little better picture quality, but has the Genesis chipset. You sacrifice some picture quality, but gain deinterlacing performance with the RP-56
    Silicon Images and Faroudja are both excellent solutions for deinterlacing, although the Faroudja is a little better than SI IMO.
  6. WilliamB
    May 4, 2000
    60
    Thanks a lot. I'd get the RP91 but it has DD5.1 built in and my receiver has that so I'd be paying extra for something I don't need. But - =do you think the pic quality is so much better than the 56 it warrants the extra $$ anyway
