Silent SVS mono amp
Discussion in 'Archived Threads 2001-2004' started by Mike Witko, Oct 23, 2002.
  1. Mike Witko
    Mike Witko Stunt Coordinator
    Jul 1, 2001
    108
    Does anyone have a suggestion for a silent mono amp for powering an SVS? The stereo amp that I currently have has a fan that is starting to drive me crazy. I don't want to spend a lot of money but I would like something that works and is almost completely quiet.
    thanks
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
  3. Mike Witko
    Jul 1, 2001
    108
    Cool it looks like SVS uses the 320W for there PC20-39. I wonder how easy it would be to use this on my subwoofer. Would I need to install it interally into the subwoofer or can I use it as an external amp?
  4. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    I would just build an external box for the amp, much like Patrick Sun and Ron-P did with theirs. You'll be able to put it anywhere, and saves you from cutting a whole in the SVS sub, NOT RECOMMENDED!
  5. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    I wouldn't try to install it internally. I'd just use it externally. Prop it up behind your equipment rack against the wall, or build a simple box for it.
    The power section should be identical to the SVS amps I think. But it won't have the same rumble filters or crossover stuff.
  6. dave alan
    dave alan Second Unit
    Aug 30, 2002
    256
    the stewart world series of class H amps should be considered when driving any good sub. they've won every innovation design award out there over the last 5 years. the stewart world 2.1 beat every other amp overall in the bass player shootout (though for bass guitar, it translates well for a sub, too).
    no fan, stable to 2 ohms, last forever build, lightweight, very efficient and excellent low end reproduction. relatively cheap, too. odd to me that more people aren't using them. give a peek, if you like:
    http://www.musiciansbuy.com/stewart_...amplifiers.htm
  7. Mike Witko
    Jul 1, 2001
    108
    quick question on the BASH. Does it have an output that would make it easy to just use a speaker wire to hook up between the BASH and the SVS?
  8. Mike Witko
    Jul 1, 2001
    108
    I just asked the above question because I don't want to do any soldering.
  9. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    My guess is it will be like other plate amps. Will have a couple wires (1-3ft long or something like that; best way to find out would be to ask Kyle I think) that you can connect to the sub. Or you could cut those wires shorter, crimp on some longer speaker wires and run those to the sub.
  10. Eric Hargrove
    Eric Hargrove Stunt Coordinator
    Nov 24, 2001
    153
    Use an old stereo amp bridged. My Adcom GFA555 drove my Ultra extremely well with a minimum of 850w into a 4 ohm load. The damping factor is much higher on an amp like this. Another good option would be something older from Carver. You should be able to find either on ebay for $300-$350 max.
