Silent Hill 2 Help needed
Discussion in 'Gaming' started by Matt Butler, Dec 18, 2003.
  1. Matt Butler
    Matt Butler Screenwriter
    Jun 23, 2001
    1,915
    2
    Ok Im in the second apt building. I dont know where to go from there. I found a desk with some riddle on it with five holes. Am I supposed to do something here.
    Help Im at a standstill.
    PS I cant get to the third floor. And no access to gamefaqs.com
  2. Christopher Cheadle
    Christopher Cheadle Stunt Coordinator
    Nov 8, 1999
    173
    First make sure you have the 3 medallions as these are part of the riddle. Once you find all of those, you will need to decipher the riddle and place the medallions in the proper order. I just got past this part and it took me a little bit of trial and error to get it right.
    If you need any more specific help, just let me know.
  3. Matt Butler
    Jun 23, 2001
    1,915
    2
    Chris,
    Are all the medallions in the first or second apt building? Do I need to worry about the third floor in the second building?
    Thanks for the reply and help my friend.
    [​IMG]
  4. Christopher Cheadle
    Nov 8, 1999
    173
    I believe they are all in the first building, but I can't remember as I had to take a break from the game between when I found the medallions and when I actually did the puzzle. I do remember that one is in the "Courtyard" behind the building.
  5. Matt Butler
    Jun 23, 2001
    1,915
    2
    Thanks Chris. [​IMG]
