JeffreyMercado
- Feb 1, 2002
Retail is $1499 Selling Brand New Unopened Factory Fresh in Double box from Monster Power for $1200 shipped.
$750,000 Connected Equipment Warranty.
Individually hand signed Signature Plate by the Head Monster.
T2 technology provides an additional layer of protection from overvoltages.
Exclusive Monster Dual Balanced Pure Power™ circuitry for lowest noise, best picture and sound performance.
Digital Microprocessor-driven blue amp. and voltmeter for instantaneous monitoring of all functions and fluctuations.
Triple-shielded 8 ft. PowerLine® 400 AC Power Cord.
Blue LED volt and green amp meter.
Signature Series HTPS 7000 with Dual Balanced Pure PowerTM Transformers
PRODUCT DESCRIPTION: MODEL: INVENTORY: U.S. RETAIL PRICE: BUY ONLINE:
Limited Edition Signature Series 7000 MP HTPS 7000 SS 109410 $1,499.95 ea.
Height: 5.25 Inches
Height - With Feet: 5.75 Inches
Width: 17.0625 Inches
Depth: 14.25 Inches
Weight: 44 lbs.
How Do You Improve Perfection?
Hot on the heels of the most successful power products launch in the history of home theater, Noel Lee, Head Monster, announces the ultimate refinement in power conditioning.
A Bold New Look for Performance Power!
New True Blue LED readouts offer a bold new look to Signature Power. The Signature power products are way over the top, says the Head Monster.
"The top-of-the-line Signature HTPS 7000 power conditioner combines the world's finest filter circuitry designed by Richard Marsh, uses triple shielded transformers with uniquely switchable balanced or isolated settings that will subdue any noise or ground loop you can throw at it!"
Plus we use new heavy-duty, double shielded PowerLine 400 power cable and ultra-sophisticated power protection that automatically resets for trouble-free use.
Signed Personally by the Head Monster, the Signature Series is Noel Lee's own personal statement on the superior look and performance of the Monster Power.
Without Clean, Balanced Power, Your Home Theater System Can’t Deliver Peak Performance
The current that comes from your wall outlets is inherently imbalanced, causing high-frequency oscillations that get picked up by your sensitive home theater system in the form of performance-robbing hum, buzz, and static. And while filtering radio frequency (RF) and electromagnetic (EM) interference can remove much of the hum, buzz, and static from your system, only a power center with perfectly balanced power can fully remove interference for the best possible picture and sound from your home theatre system.
Monster’s Home Theater Power Source HTPS7000 Provides Balanced Power
and Ultimate Power Conditioning for the Best Possible Home Theatre Performance
HTPS7000 employs cutting-edge technology to perform the difficult task of balancing the power used by your home theater system. Equipped with unique twin isolation transformers, HTPS7000 refines and matches the current from your wall outlet for a perfect balance between the negative and positive current flowing to and from your home theatre components. The result is a virtually complete elimination of power line oscillations and the hum, buzz, and static they cause. With HTPS7000 as an integral part of your home theater system, your audio components will perform with stunning clarity, significantly expanded frequency response, and powerfully precise imaging, while your video components will deliver clearer, sharper images, brilliant colors, and a static-free picture.
HTPS7000 is equipped with Monster Power’s Clean Power Stage 5 v2.0 circuitry. Clean Power Stage 5 v2.0 uses five ultra-advanced isolated filters to provide further rejection of the electromechanical and radio frequency interference present in your AC power lines, as well as your home theatre components. These include two digital filters, analog audio and video filters, and a high-current audio filter. By using optimized filters for each application, HTPS7000 is able to minimize the types of interference that affect each individual application for ultimate interference rejection.
Microprocessor-Controlled Sequenced Switching and High-Capacity Surge Protection Ensure Ultimate Safety for Your Expensive Home Theater System Components
HTPS7000 features intelligent microprocessor-controlled turn-on sequencing to protect your components from damage that may occur when components are powered on in an incorrect sequence. And unlike many other power centers which require switch programming to be done from the rear, HTPS7000 allows switching to be performed through its front panel for ultimate convenience.
HTPS7000 also provides superior surge/spike protection for your home theater system with a surge/spike capacity of 3145 joules, the highest capacity currently available to consumers. In addition to 12 surge-protected AC outlets, HTPS7000 has surge-protected coaxial and RJ11 phone outputs for protection from phoneline and cable surges. HTPS7000 offers a $750,000 connected equipment warranty for repair or replacement of connected components damaged from surges and spikes that occur when they are properly connected to HTPS7000.
Enjoy Monsterous Home Theater Performance
When you want the highest levels of performance, protection, and power conditioning for your home theater system, there is only one choice: Monster Power’s Home Theater Power Source HTPS7000.
Height: 5.25 Inches
Depth: 14.25 Inches
Weight: 44 lbs.
