shouldn't a 4 ohm speaker be louder than a 6 ohm one?
Discussion in 'Archived Threads 2001-2004' started by Luke_Khuc, Apr 14, 2002.
  1. Luke_Khuc
    Luke_Khuc Stunt Coordinator
    Feb 12, 2002
    167
    Hi,
    I bought a bohlender center speaker which is rated at 4 ohm. I am trying to break it in and found out that my old jbl (6 ohm) sounds MUCH louder than the bohlender. I thought speakers with lower impedance will sound louder. These two speakers are connected to an old Sony receiver. Thx for your inputs.
  2. Joe Casey
    Joe Casey Stunt Coordinator
    Mar 2, 1999
    225
    Speaker sensitivity (rated db output for 1W at 1 meter) measures 'loudness' of a speaker, nominal impedance does not. For example, a speaker rated at 90 db sensitivity will produce 90 db of sound when supplied 1W of power at 1 meter. That same single watt, when supplied to a speaker of 87db sensitivity, will effectively be half the 'loudness' at 1 meter (a doubling of power increases output by about 3 db).
  3. Mark Larson
    Mark Larson Supporting Actor
    Mar 3, 2002
    537
    Good reply, Joe, and i add my two cents:
    You thought it would be louder because your receiver sends more power to a 4 ohm load, right?
    Well, your assumption is correct, but hearing doesn't work 'naturally'.
    Your JBL's might have been more sensitive. A 3dB sensitivity increase equals a doubling in amp power.
    So, if your 6 ohms were drawing 130 wpc, your 4 ohms (maybe) are drawing 160 wpc (it varies), but there is almost NO dicernable difference in loudness.
    To get a doubling in loudness, you'll have to double the amp power. The hearing scale is logarithmic, so to double it, you'll have to increase power by a factor of 10. Thus, double of 100 watts is actually 1000 watts.
    I'm not sure whether a 3 dB increase in sensitivity equals a doubling in perceived power (ie jump from 100 to 1000 watts), and will be happy if someone shed some light on this.
    [​IMG]
  4. Matt Meyer
    Matt Meyer Stunt Coordinator
    Mar 29, 2002
    117
    I think 10db is a doubling of "volume".
    I think,
    Matt[​IMG]
  5. Wayne A. Pflughaupt
    Aug 5, 1999
    6,207
    56
    9,110
    Katy, TX
    Wayne
  6. Luke_Khuc
    Feb 12, 2002
    167
    yup.. I just checked. the JBLs are 91dB while the Bohlender is 86dB.. Thx all.
  7. Geoff L
    Geoff L Screenwriter
    Dec 9, 2000
    1,693
    Luke,
    Don't know if you have the whole set all round or what model, but how is the build quailty on the ~{New BG Center}~????
    Geoff
  8. Luke_Khuc
    Feb 12, 2002
    167
    Geoff,
    I HATE ubid.com!!! I was going to get a pair of 420s also, but I had soo many problems with ubid and ended up with the center only. (breathe Luke breathe. It's okay). Anyway, I have the center channel 220 and it's one heavy SOB. The build quality is like that of a tank. Its binding posts are a little bit smaller than ones on my Rotel 1095. One think I don't really like is the irremovable grill. I want to see what I've paid for ya know. There are several links you can look at.
    From their website: BG 220 center and manual
    Review from hometheaterhifi.com
    You can check audioreview.com for more reviews.
  9. Mike Veroukis
    Mike Veroukis Second Unit
    May 8, 2001
    455
    Canada
    Michael
    I'd just like to jump in here with a little comment. If you wish to make something twice as "loud" then you want a +6db in volume, not +3 or +10 like some have mentioned in this thread. If you want to test this out load something like Cool Edit Pro (or any good sound editor) and test it out yourself. In CoolEdit you can "amplify" using a db scale or a % scale. If you do a +6db you're amplifying by 100%, in effect doubling the volume.
    I'm no expert of course, so someone please correct me if I'm wrong.
    - Mike
  10. Joe Casey
    Mar 2, 1999
    225
    What I said was that a 3db gain in output requires a doubling in power, not that a 3 db increase in output is effective loudness doubling.
  11. John Kotches
    John Kotches Cinematographer
    Mar 14, 2000
    2,635
    THere are a few things here.
    There is output power, that's 3dB for a doubling of output.
    There is perceived loudness, which (generally speaking) requires 10dB for a doubling.
    I'm not 100% sure on doubling SPL, and what the ramifications are.
  12. Luke_Khuc
    Feb 12, 2002
    167
  13. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    The difference is more subtle 3-4 meters while obvious from 0-1 meter. Sitting 50 meters and 51 meters will most likely sound identical to the human ear.
  14. John Kotches
    Mar 14, 2000
    2,635
    Yes Luke,
    Because the launch of a planar driver is a cylindrical wavefront vs. a point sources spherical wavefront, the degradation is a lot less severe over a distance.
    So, you "gain sensitivity" in a manner of speaking over distance with planars.
    Thanks for quoting from my review [​IMG]
