Should I use a progressive scan player if...
Discussion in 'Playback Devices' started by anthony_b, Oct 2, 2003.
  1. anthony_b
    anthony_b Screenwriter
    Aug 18, 2000
    1,071
    3
    Should I even bother to purchase a progressive scan player if my HDTV upconverts everything to 1080i ?.
  2. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    Yes, the de-interlacer is better in the top-rated progressive DVD players. Also HDTVs don't usually convert 480p input to 1080i, most display 480p native except for fixed pixel panels like plasma displays and they scale everything to their native non-standard resolution.
  3. anthony_b
    Aug 18, 2000
    1,071
    3
    Don, are you 100% sure of that ?...only becuase the manual for my TV states that it will upconvert everything. It's a JVC AV48WP74.
  4. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    I'm not familiar with your set, but perhaps it is one of the exceptions. I would still get a good progressive player and compare to see which is better, since you are still limited to 480 lines from the source. You could always return the DVD player if it isn't noticeably better.
    DJ
