I was thinking of putting my sub behind the TV? Look here. Would this be a good spot? You can also see how big my room is here. Based on these pictures, what do you all recomend.
Jim
It would not hurt to try it there. Get you about 15 feet of wire so you can move it to another location if necessary. The corners are the best so that will probably be fine. These subs have so much bass that you will probably like it no matter where you put it.
I have considered putting my 20-39CS+ behind my tv as well (same corner setup you have). The only worry I have about it is the effect it will have on my tv. I have a Panny 36HX41, and with the sub about 3 feet from the tv right now, I occasionally see "ripples" in the picture. I'm not sure what this is from, and until I figure it out, I'm not going to risk putting my sub that close to the tv...
Well, My SVS 20-39PC should be her today! Wooo Hooo!!! Now, for room placement. I don't think I want to put it behind my tv due to the fact that It could mess up my picture, and cause my DVD player to skip. My options are some what limited as you can see in this picture HERE. What do you all think about puting it in that little corner to the left of the fire place? Should that work? Any Ideas... Thanks for the help!
...Jim
