Spector
- Jan 30, 2002
Well I'm looking into getting a home theater system. I have heard good things about Paradigm so I'm really considering getting them for my setup.
I'm skipping the rear speakers for now and just getting the main speakers, sub, receiver and center.
Would it be wise to get Studio 20's or should I go for some Monitors in the same price range?
I'm thinking SVS PC sub used (it doesn't need an outside AMp right?), Paradigm Studio 20's and probably the CC 370 center speaker. I'm not sure how much I should spend on a Reciever right now. I'm trying to keep the budget at 1500.
I'm going to try to use my second PC as the DVD player and jukebox. Not sure what else.
What I really just wanted to know is if I should go with Studi 20's or Montiors (i'm assuming I can get bigger monitors for the same price range)?
