John Pine
- Feb 27, 2002
- John Pine
My setup is used almost exclusively (80/20) for music. Primarily I listen to Hi-Res audio (SACD/DVD-A), concert DVD’s and of course redbook CD’s. I listen to everything from Blues and Metal to Classical and Bluegrass. Volume-wise, I typically listen in the 90–100db range with an occassional 105 db peak. My mains are full size towers rated down to 37Hz, so the sub crossover will be turned down to 40 or 50Hz. A concern I have is my listening room is fairly large (23’x 18’ w/14’ vaulted ceiling). Which one would best match my needs? Any feedback? Thanks John
p.s. I asked Ron at SVS, but he wouldn’t commit on one over the other. He said either one would do nicely.
Toshiba 35"
Parasound HCA-2003(L/C/R)
h/k PA2000(rears)
h/k AVR 525(pre-amp)
Denon DVD-2900
JBL S310-II's
JBL S-Ctr II
JBL S36-II's(rears)
Velodyne CHT-12 (currently listed on eBay)
23'x18'x14' (LxWxH)
Toshiba 35"
h/k PA2000(rears)
Denon DVD-2900
JBL S310-II's
JBL S-Ctr II
JBL S36-II's(rears)
23'x18'x14' (LxWxH)
