JaimeC
Grip
- Oct 24, 2001
I am building my very first home theater and started to look at the Denon receivers.
My first question is should i get the 5.1 or the 6.1 receiver. The room in my home which will house the home theater system is very large (about 20 ft. x 30 ft.) and already has the ceiling speakers built in for rear surround.
I was looking at the Denon #AVR-3802 which has Dolby digital, dolby pro logic II & DTS ES with a Discrete 6.1 A/V receiver. But then I started to look at the next line up, the AVR-4802 which has the THX surround EX/DTS 6.1 Discrete as well. Obviously, the 6.1 costs more but can anyone tell me if its worth the cost difference.
Lastly, if you were to choose the two most importance pieces of equipment in a home theater that makes or breaks the system, which would you spend most of your money on. I have heard speakers is the first.
JaimeC
JaimeC
