Kevin. W
- Oct 27, 1999
I plan on opening up my new Panny PT47WX52 tommorrow and doing the manual and E focus. Should I "E"/Manual/"E" focus or the other way as per instructions on Panny.tv? Thanks
Kevin
Kevin
Cover the other lenses over when doing thisWhat do you use to cover them? What test pattern do you use? And should I clean the lense while I'm in there? If so with what? Thanks
Kevin
