JoelM
- Dec 16, 2001
Well I'm now torn between getting a 65" HDTV or a projector with a 100" screen. I have 5k to spend and I'm leaning more toward projection. Here's the thing...I am using this viewing device for DVD's only. It will be in a home theater room that is 30X20. Can a projector look as good as a HDTV. I've never seen one in action. Demos of projectors are a little bit more rare then going to your local Best Buy to see that Tosh65. My main concern is picture quality and if a 65 yields a better picture then I will go with that. The room is completely dark no windows if that helps.
