Should I attempt this fix?
Discussion in 'Archived Threads 2001-2004' started by Angelo.M, Nov 18, 2002.
  1. Angelo.M
    Angelo.M Producer
    Aug 15, 2002
    4,007
    I have a 60-inch analog RPTV and have noticed while converging that the screen image has 'shifted' to the right. I have the service codes for my set (a Philips). Is this something I can safely adjust from the service menu, or should I let a professional handle it?
    AM
  2. Jan Strnad
    Jan Strnad Screenwriter
    Jan 1, 1999
    1,004
    Adjusting convergence is fairly safe, but you need to write down your service codes first in case you accidentally change something you didn't mean to change.
    Adjust the green lines for proper geometry, then adjust the red and blue lines to match.
    Jan
