Should I angle my mains away from listener?
Discussion in 'Archived Threads 2001-2004' started by Adam Bluhm, Aug 30, 2002.
  1. Adam Bluhm
    Adam Bluhm Supporting Actor
    Feb 9, 2002
    611
    Okay. Here's the deal.
    My mains are all too close together. They're inches from the television. To possibly simulate them being further apart, would it be wise to angle them away?
    Thanks for any help.
  2. ChrisMatson
    ChrisMatson Cinematographer
    Dec 14, 2000
    2,181
    110
    Most people recommend placing the main speakers ANGLED IN, toward the listening position. I think that you may create a more diffuse sound field by angling them out, but that could destroy the sound stage. Would it be possible to move the speakers further away?
  3. Adam Bluhm
    Feb 9, 2002
    611
    No. That's the problem. It's a bedroom setup and believe me, I've exercised all my options. This would be a last resort deal. I realize I'd loose some staging, but was curious if I would gain any larger sweet spot and, like you said, diffuse the sound somewhat. I guess I'll experiment with it. [​IMG]
  4. Geoff S
    Geoff S Stunt Coordinator
    Jun 1, 2002
    239
    Like anything else try it and test it and see if you like it. Angling them in, aka, "toeing them in" may result in a better stereo effect, but if they're rather close together having them facing strait forward is the best option I think.
  5. Pete H
    Pete H Stunt Coordinator
    Mar 5, 2000
    52
    Toe in is speaker and room dependent. Straight on is slightly unusual and I've only heard of one or two say they like toe out. Try it but be patient, speaker placement is a slow process (at least for me).
