Should I add the Dayton 10" sub ???
Discussion in 'Speakers' started by Henry Hughes, Apr 12, 2004.
  1. Henry Hughes
    Henry Hughes Agent
    Dec 17, 2002
    29
    I already own an SVS PB2-ISD. This is in a 14x20 room. I know I don't need the extra bass, but would it make a difference if I got the Dayton? I mean at 109 dollars, I'm just wondering if I could fit it in my system.
  2. Anthony*B
    Anthony*B Stunt Coordinator
    Aug 6, 2003
    205
    i cant imagine it helping much (I love mine, but would obviously "graduate" to an SVS in a New York minute if I could afford it...) take that 109$ you seem determined to spend & use it on some good DVD's/CD's instead...just my 2 cents! good luck!
  3. steve nn
    steve nn Cinematographer
    Jan 12, 2002
    2,418
    As good as the Mighty tinny is for the $$ please don't add it to the SVS bass. You will notice a down-grade in sound I assure you..... [​IMG]
  4. Greg-ST
    Greg-ST Stunt Coordinator
    Jan 27, 2003
    193
    MuneebM has one paired with his HSU STF-2. The Dayton is behind his seating position to add the extra kick.
    In the end it may or may not degrade the bass quality depending upon your room and the location of the subs.
