Ryan*Pr*
- Jul 1, 2003
I have calibrated my system with several different speaker placements and all had the same problem. BTW, I am running Onkyo TX-SR700, Paradigm CC170 center, Titans F/R, and a PDR10 sub. I have the levels matched, but it is hard to hear spoken dialogue compared to all the sound effects. I feel like I have to turn the volume up more when there is dialogue and then put it back down when there is an action scene because otherwise it will half kill my ears.
I currently have the center on the top of an entertainment unit, pointed down to ear level (currently 1-2 feet above ear level). My fronts are not toed in, with the tweeters about 6 inches below ear level. The rears about 6 inches above ear level.
I have to raise my center level about +3 from actual calibration and even then it doesn't seem like dialogue is as clear as it should be. I don't want the center level to be too high on action scenes and have it louder than the other speakers. Do you have any suggestions?
EDIT: In case you wondered, my settings are: FL:0 FR:0 C:-1 RL:-4 RR:-4
