BAF
- Jul 10, 2008
- Bruce A Finstead
While helping a friend hook up his receiver, I was shocked (electrically) for reasons I cannot understand. This is a new setup. He had speaker wires installed to various rooms during his remodel;they terminate in banana plug receptacles behind his receiver, but are unlabeled. In trying to ascertain which plugs were connected to which speakers, I touched a D battery across the red and black receptacles for individual speakers, and was in large measure successful in hearing the appropriate sound from various speakers.
It was when touching across a set of wires that were probably not connected to speakers when I was shocked. The patch cords I was using had brass connectors which I held. When I was holding the connectors, no problem. When I held the connectors, and touched the two ends of the D cell, I was shocked with what was probably about 110 volt, low current. Measuring across the receptacle contacts showed no voltage. I tried it again with the same shocking results. I don't understand how this is possible. Of note is that connecting here may have previously blown his amp! Any suggestions?
