shiva or titanic?
Discussion in 'Home Theater Projects' started by JimV, Apr 24, 2005.
  1. JimV
    JimV Auditioning
    Apr 7, 2004
    9
    i'm gettin close to pulling the trigger on one of these 12" kits, anyone ever hear both and what was your impression of them? i would go with the 85 liter shiva or the 12" titanic from PE. i'm about 70 music 30 movies, also, is the shiva Enclosure from Acoustic Visions finished? i'm thinking either way it should be a big improvment over my klh 12" that i currently run. thanks
    ps. no heckeling over the klh, it was only $70 and filled a void
  2. Kyle Richardson
    Kyle Richardson Screenwriter
    Jan 1, 1998
    1,073
    The Shiva isnt currently available so you may want to look at the Titanic a bit closer. [​IMG]
  3. Aaron Howell
    Aaron Howell Stunt Coordinator
    Nov 19, 2003
    196
    Hey Kyle, is the upcoming 12" shiva even going to be the same as the old shiva?
  4. Eric Ha
    Eric Ha Stunt Coordinator
    Sep 27, 2004
    146
    Take a look at the Dayton DVC drivers. They're VERY similar to the Shiva and Tempest, (made by the same company I think?) but require smaller enclosures. Do a search on this site for "DVC" and "Shiva" in titles only.
  5. Eric Ha
    Sep 27, 2004
    146
  6. Kyle Richardson
    Jan 1, 1998
    1,073
    Aaron - no, they are going to be slightly different although details have not been released.
    Eric is correct, the Dayton DVC drivers are very similar in price and performance to the Shiva and Tempest.
  7. JimPeitersen
    JimPeitersen Second Unit
    Dec 7, 2001
    470
    You can also look at the Stryke (AE) 1204 driver (AE, or ApexJr. websites.) The Ascendent Audio Atlas 12 might work for you as well.
    JP
  8. RobertFirment
    Dec 28, 2004
    23
    The question should be Atlas or Avalanche.
  9. Dan Wesnor
    Dan Wesnor Second Unit
    Apr 28, 1999
    389
    I have both a Shiva and a Titanic Mk III. They are both good, but the Titanic has better Bl curves, and should be more linear over a wider range of displacement - i.e., less distortion. It also costs more.
  10. Eric Ha
    Sep 27, 2004
    146
    Right, cost vs. performance is an issue ony decided by the individual consumer. All drivers spoken of will deliver very good performance.
  11. JimV
    JimV Auditioning
    Apr 7, 2004
    9
    so dan, am i hearing you right, go for the titanic? also, does the Atlas or Avalanche have a kit? cuz right now i'm putting in long hours and don't have time to do it
  12. Eric Ha
    Sep 27, 2004
    146
    If you're willing to spend $536 on the Titanic kit, I'd buy an SVS PB12-ISD for $60 more. You'll get significantly more sub-25hz output, and no assembly is required. DIY subs are only reasonably cost effective if you are willing to build the cabinet. Otherwise, online companies like SVS and HSU are very hard to beat.
