Shiva or Tempest sonotube?
Discussion in 'Archived Threads 2001-2004' started by jeff lam, Jan 3, 2002.
  1. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    I was almost sure I was going to use a shiva due to wanting a small footprint but now I'm hearing things about the tempest just killing anything else in it's way that has a 12" diameter. Can anyone help me decide? What would be the differences between the shiva and tempest sonotube as far as performance is concerned? Figure tuning to be around 16-18Hz. Height is not an issue but footprint is kind of important. What are the options?
    Thanks!
  2. Dustin B
    Dustin B Producer
    Mar 10, 2001
    3,126
    Well I'm sure you know my opinion :p)
    You might be able to get 14" sonotube to work with a Shiva, 16" for sure. I know you can use 18" with a Tempest. Although, if you mounted the legs to the side of the tube like I think Mike Knapp did you might be able to use 16". 16" would be hard to get a large volume out of though.
    I've never heard a Shiva, but I think the only big differences are the Tempest's Vd is a litre more than the Shiva and the Tempest costs and extra $15-$20. Sound wise I would think similar allignments (not identical enclosures but what constitutes a particular allignment for each driver) would sound almost the same, just the Tempest will go louder and a little lower.
    If you can swing 18" sonotube I personally wouldn't hesitate on taking a Tempest over a Shiva.
  3. Patrick Sun
    Patrick Sun Studio Mogul
    Jun 30, 1999
    38,766
    489
    9,110
    Tempest.
  4. Andrew Pratt
    Andrew Pratt Producer
    Dec 8, 1998
    3,806
    I've built subs using the shiva and tempest and I see no reason to use a shiva if you can help it. If you can go Tempest or the 15" DVC from Parts Express it is essentially the same driver but can go in a slightly smaller box
  5. Hank Frankenberg
    Hank Frankenberg Cinematographer
    Oct 13, 1998
    2,573
