Shiva in a 15" cube?
Discussion in 'Home Theater Projects' started by RobLJ, Mar 2, 2004.
  1. RobLJ
    RobLJ Stunt Coordinator
    Jan 7, 2004
    81
    I'm wanting to build a Shiva based sub. It has to be small and compact. If I use WinISD, I come up with a decent curve. I checked google to see if anyone had done this yet, but I didn't find anything like that.
    What would you expect it to sound like? Thanks for the input.
  2. Shawn Shultzaberger
    Shawn Shultzaberger Supporting Actor
    Dec 2, 2000
    705
  3. Aaron Howell
    Aaron Howell Stunt Coordinator
    Nov 19, 2003
    196
    I've seen the adire DPL 12 suggested to go into a 16" cube. If you are looking for something in the size range of a 15" cube this would probably be your best bet. I think it's only $25 more.
  4. RobLJ
    Jan 7, 2004
    81
    Thanks for the info guys. I'll look into that DPL12 setup. [​IMG]
  5. DaveWo
    DaveWo Auditioning
    Nov 10, 2003
    11
    Yeah, I built a 16" cube for my DPL12 and used the Parts Express 250 Watt Amp. It sounds great. Blends perfectly with music, sounds awesome with movies. I highly recommend this set up.
  6. MattD
    MattD Stunt Coordinator
    Feb 29, 2000
    166
  7. Aaron Howell
    Nov 19, 2003
    196
    Just email adire. There is no better way to get accurate info.
  8. DaveWo
    DaveWo Auditioning
    Nov 10, 2003
    11
    I did use poly-fill to stuff it, but I honestly don't remember how much I used. A pretty decent amount though. (I know, that doesn't help much, lol, sorry)
