Shiva impedance worries...
Discussion in 'Archived Threads 2001-2004' started by Peter Johnson, May 18, 2001.
  1. Peter Johnson
    Peter Johnson Stunt Coordinator
    Nov 12, 2000
    136
    OK, planned project for a first DIY project so far is:
    Shiva II in a 127L box, tuned to 19-20Hz.
    nOrh LE monoblock, [email protected], which will almost double into 4ohm.
    ESP 4th order active xover and PS at www.sound.au.com
    When I plot this in LSPCAD, everything looks good except the impedance graph worries me. There are massive peaks at 35 and 11Hz, of around 60ohms. Is this normal, or is it a problem?
    It will be for music 90% of the time.
    Is the above sub OK?
    Basically I am aiming for about the most flexible sub possible. By buying all seperate components, I can minimise risk, which is VERY important for me in a first DIY project. The active x-over can be easily altered by changing
    resistors, I can seal the sub by plugging the port, and the LE amp is just a simple power amp..hopefully it is as a good an amp as it is cracked up to be. Total cost will be around $400. I am a student, so this a A LOT of money.
  2. Mark Hayenga
    Mark Hayenga Supporting Actor
    Jun 11, 1999
    607
    The peaks are normal and won't affect anything. You should be 'good to go' with that setup. Good luck!
    Mark Hayenga
    www.hayenga.com
    "Saru mo ki kara ochiru"
