Shiva cutout???
Discussion in 'Home Theater Projects' started by darren_s, Dec 28, 2003.
  1. darren_s
    darren_s Agent
    Dec 21, 2003
    30
    Just about finished with Ebs shiva sub only cuts left are recess around 11' cutout. I am having trouble finding a rabbet bit the correct size, so I decided to get one thats 1/4 radius and make 2 passes to get 1/2, is this the correct size 1/2 for shiva recess?? and how deep?? 3/8??
  2. Brian Fellmeth
    Jul 30, 2000
    789
    Whoa, you can't do that. Where is the bearing going to ride on the second pass ?
    Instead, cut a circle the shiva's outer diameter (I presume 11 inches) only as deep as the flange. Move the jig to 10 and 7/8 and cut again to the same depth. Move the jig to 10 3/4 and cut the same depth then again at 10 5/8. Finally, cut all the way through at 10 1/2. You will have an inner through hole at 10, a 1/2 inch rebate and an outer circle at 11. If your baffel is in 2 layers that have not yet been laminated, there is another option- Cut one layer through at 10 inches and the other at 11, then glue together. To do this, it is necessary to temporarly screw the layers together and drill the pilot hole through both. Then, the original screw holes realign the circles perfectly.
  3. darren_s
    darren_s Agent
    Dec 21, 2003
    30
    Thanks for reply, I allready have 11" hole cutout, the Shiva is 12.25 total diameter, I have a jig so I guess I really dont even need rabbet bit, I can use my 1/4 upcut to get same results, I have 11' cutout screwed to board under sub bottom plate that I use to connect jig to center point, anyways I dont have the shiva yet and am not sure if 1/2 recess will be enough?? and depth?? what is correct depth??
  4. DaveKahler
    DaveKahler Stunt Coordinator
    Nov 23, 2002
    73
    To flush mount the shiva, cut a recess that is 3/4" deep.
  5. darren_s
    darren_s Agent
    Dec 21, 2003
    30
    3/4 depth?? do you mean Radius? Can anyone tell me if they have lined the walls of there EBS with poly batting sheets?? or leave it
  6. Brian Bunge
    Brian Bunge Producer
    Sep 11, 2000
    3,716
    The thickness of the frame and gasket is right at 3/4". So the depth of the recess needs to be 3/4". So your baffle needs to be 1.5" thick in order to recess the driver.
  7. darren_s
    darren_s Agent
    Dec 21, 2003
    30
    Thanks Brian, I am using 3/4 MDF ?? I cant flush mount without adding another layer??
  8. Brian Bunge
    Sep 11, 2000
    3,716
    If you are using 3/4" for the baffle with the driver surface mounted, it takes another 3/4" thick piece to completely flush the driver. At least that's the way it is with the DVC 12's, which I belive have the exact same basket and cork gasket as the Shiva. I've used both and never noticed them looking any different.
  9. Rich-R
    Rich-R Extra
    Oct 7, 2003
    19
    Brian, what to you use to mount downfiring subs? Drywall screws? I am getting ready to do an ebs av12, downfiring. Thanks, rich
  10. darren_s
    darren_s Agent
    Dec 21, 2003
    30
    Rich-R This is my first DIY sub but I do know that it is better to use the Tnuts if you use drywall screws they will hold just fine but if you take your driver out more than a couple times the holes from screws will weakin, good luck
  11. Brian Bunge
    Sep 11, 2000
    3,716
    I hate T-nuts. I use the coarse thread panhead screws that PE sells. Drywall screws would work too. If I want something with more holding power, like when I build Tumults, I use threaded inserts.
  12. DaveKahler
    Nov 23, 2002
    73
    I agree with the coarse thread pan head screws from parts express. They are THE BEST screw for MDF, period.
  13. darren_s
    darren_s Agent
    Dec 21, 2003
    30
    Brian, After geting the EBS all together It is looking like the 4" port will be very close to Amp if not hitting it, have you built a EBS with Amp in rear??
  14. Brian Bunge
    Sep 11, 2000
    3,716
    No, I haven't built an EBS alignment sub with the Shiva. If the port is so long that the port is that close to the amp then you've definitely got a problem.
