Shiva and Resistively Damped Mode
Discussion in 'Archived Threads 2001-2004' started by Ben Ven, Mar 23, 2002.
  1. Ben Ven
    Ben Ven Stunt Coordinator
    Mar 6, 2002
    61
    I am new to the forum and this topic may have been covered in the past. I did a search but came empty, so I am going to ask anyone with a Shiva if they can help.
    I read in the Avatar White Paper dated back in 1999 about a resistively damped operation or RDO for short. I have had my Shiva for 1 1/2 years. It is powered by an old Pioneer Dolby Pro Logic receiver. I output the LFE chnnel from my DD receiver to the preamp input of the Pioneer. This sendds 125 W times 2 to the Shiva. Both voice coils are powered. Has anyone tried what Avatar (Adire) calls RDO. They state that if you power 1 voice coil, you can use the second voice coil as an electrmagentic brake. I was just wondering if anyone has tried this mode of operation and what it sounds like.
    Thanks.[​IMG]
  2. Ben Ven
    Mar 6, 2002
    61
    Hi Jack,
    Thanks for your reply. I am using the Shiva in a 35 L sealed enclosure, which I figure gives a Qtc of approximately 0.82. Seems like RDO is not a good idea for my highish Qtc system. I wasn't quite sure how RDO worked but now I do thanks for your input.
  3. Ben Ven
    Mar 6, 2002
    61
    Tell me about it!! The only way I could keep the Shiva in my family room was to put it in the corner behind my wife's chair (she gets a real good massage when watching movies now!). She said she did not want to see that "ugly box". So, much to my dismay , I had to build the box smaller (from 60 L and that is still small) Anyway, I have stuffed it pretty good and I have about a 3dB peak centered around 85 Hz in the room. Otherwise it is pretty flat up to 125 Hz.
  4. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    That's very nice in-room response, actually. If you ever want to try something different in that box, the
    Dayton 12" DVC woofer from Parts Express is very similar to Shiva (essentially a clone), but its lower Vas makes it suitable for smaller boxes. I used it in a sealed box of just over 1 ft^3 (the details of which are about halfway down this page), and it worked out very well. Briefly mounting my Shiva in the same box really threw the inferior transient response of the much-higher Qtc into sharp relief.
  5. Ben Ven
    Mar 6, 2002
    61
    Thanks Jack. I will be remodelling the family room and my HT in the next year. I was actually thinking of using a pair Stryke's SAE1024.
    I would like to hear from anyone aho has experience with these drivers? And if so, how do they compare with the Shiva (they look identical and are made by the same manufacturer-Eminence)and the Parts Express 12".
    Thanks.[​IMG]
