Shiva and 12" sonotube.
Discussion in 'Archived Threads 2001-2004' started by Jedd, Mar 16, 2002.
  1. Jedd
    Jedd Second Unit
    Feb 5, 2002
    298
    What do you think, is it possible to seal 12" tube (can be picked up at HD) with the shiva driver? And use it in upfiring configuration?
  2. Harry Lincoln
    Harry Lincoln Stunt Coordinator
    Sep 29, 2000
    193
    Can't see why not, the endcap at the driver end would probably need to be larger then 12 inches though. It might be easier using a 14 or 16 inch tube.
    Harry.
  3. Jedd
    Jedd Second Unit
    Feb 5, 2002
    298
    Home Depot carries 12"x48" tubes for $6 or $7, but it's the biggest size thay have.
    Endcap must be, or it's possible to use a driver to seal the tube?
    I alway was wondering also - why to use 2 endcaps from the one side, is it so hard to glue only one in, so no air get out?
