Shielding a DIY kit
Discussion in 'Home Theater Projects' started by JoelTaylor, Aug 20, 2004.
  1. JoelTaylor
    JoelTaylor Auditioning
    Jul 27, 2003
    6
    Hi I have built a kit from an Aussie crew called Accusound. The centre channel kit did not come with shielded drivers. There are 2 x 6" 120w drivers. They are placed about 1.5 foot above the TV and still cause interference with the picture. I went to a local guy who makes custom speakers and he suggested lining the box with stainless steel. I did this but with no success. Can someone please give me some advice on shielding this box?
    Thanks for your time
    JOEL
  2. MarkRoberts
    MarkRoberts Stunt Coordinator
    Oct 20, 2002
    167
    I believe what you are looking for is "bucking" magnets. You glue them or otherwise attach them to the inside of the cabinet in opposite polarity of the driver magnets. They should be trying to push each other away. I am sure the veterans on the site might have some tips or tricks to help you.
  3. Andrew S-
    Andrew S- Stunt Coordinator
    Aug 6, 2003
    67
    Stay away from expensive materials. Just get some baking sheets and cut them to the right size to block where you need it. You can double up if needed.
  4. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    You should smack the local guy in the head!
    You should use 16 gauge sheet metal. Line the insides with it. Don't bother with the back or the front baffle
    Then as was suggested use bucking magnets.
    You need to be careful with the baking sheet recommendation many of them are aluminium and that doesn't work.
    If you're feeling rich them pop for some MuMetal it's best shielding available
  5. Andrew S-
    Aug 6, 2003
    67
    YEah I guess I should have said non alum [​IMG]
  6. JoelTaylor
    Jul 27, 2003
    6
    Where do I get these "bucking magnets"?
    I am in Australia.
  7. JoelTaylor
    Jul 27, 2003
    6
    When you say sheet metal ThomasW how does that differ from sheet stainless that I have used?
    My brother is a sheet metal worker and he says that stainless is sheet metal.
    Are you referring to mild steel?
    Thanks for your help.
  8. Paul His
    Paul His Agent
    Jan 10, 2004
    29
    Your sheet metal needs to be a ferrous metal - steel. That's why your stainless isn't working - it's non-ferrous, non-magnetic, exactly the opposite of what you should be using.
    Paul
  9. JoelTaylor
    Jul 27, 2003
    6
    Thanks Paul. I will get some.
    Can anyone point me in the right direction to buy the "Bucking Magnets"
  10. ThomasW
    Nov 6, 1999
    2,282
    I don't have a clue where to get bucking magnets in AU. Parts Express has them for cheap BUT they're heavy.
    Might check in the DIY Audio loudspeaker form, lots of people from AU post there.
