Sherwood-Newcastle Amp -- Reviews please
Discussion in 'Archived Threads 2001-2004' started by Brian AM, Feb 4, 2002.
  1. Brian AM
    Brian AM Stunt Coordinator
    Jan 9, 2002
    86
    I was just wondering if anyone had experience with the 9080 five channel amp... How would you say it compares with mid-fi amps like parasound, rotel, NAD, etc???
  2. John Tompkins
    John Tompkins Supporting Actor
    Aug 30, 2000
    660
    Hello this is my first post but I have read these boards for years. I have nht 2.9, ac-2 and vs 2. along with two svs for a 7.1 setup and Im using denon 4802 as a pre-amp. I have gone through about 10 different amps in the last year or so. I bought the Sherwood am9080 not expecting much because of the low price. Boy was I wrong, this amp is sweet, powerful and never fatiguing. Great for home theater and music, especially rock, female voices and strings. I bi-amped the 2.9s using fourchannels and last channel for center and this works great with my hard to drive nhts. The Sherwood bested the 4802s internal amps easily. Now for the controversy..it is better in my system then the rotel rb993, rotel rb-985 which I thought were to grainy and a tad bright.I have a McCormack dna-1 deluxe which is a very expensive amp and I prefer the Sherwood! who would have thought ? I also have owned carver 4.0t which is 375 watts but think the Sherwood sounds as powerful. Also have had HK pa5800-loved the sound but needed more power...I hope this helps thanks I just want to say that this is just my opinion and in the end you will have to try them for yourself because I have been mislead plenty of times by reviews
  3. Brian AM
    Jan 9, 2002
    86
    I appreciate your input John. I just purchased one and have yet to receive it. I'm hoping that the 120 watt per channel will be more suitable for my Axiom ti80's than the 85 wpc Parasound I'm running them with now.
  4. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
  5. Ricky T
    Ricky T Supporting Actor
    Oct 28, 1999
    921
    Can the Sherwood amp be turned on/off by a non-sherwood prepro's DC trigger?
  6. Philip Hamm
    Jan 23, 1999
    6,873
    2
    I have no idea.
  7. Jeff Hipps
    Jeff Hipps Stunt Coordinator
    Feb 2, 1999
    194
    REVIEW Sherwood Newcastle AM-9080 multichannel amplifier, $1199.95 list
    etown.com -- April 30, 1999 -- Its specs hint that this amp is the real thing. Each
    of the Sherwood Newcastle AM-9080's five channels is rated at 120 watts
    into 8-ohm loads, 20 Hz to 20 kHz, less than 0.05 percent THD (total
    harmonic distortion), all channels driven. Connect it to a 4-ohm load
    and you'll get 200 watts per channel (wpc) at less than 0.09 percent
    THD. There's even a 2-ohm rating, which provides 320 wpc at less than
    0.09 percent THD and supports the company's claim that this amp will
    operate into very low-impedance loads. Designed as a matching companion
    to the Sherwood Newcastle AVP-9080R surround preamp/processor, the
    AM-9080 multichannel power amplifier is one of the more outstanding
    audio values I've come across in recent memory.
    Technically inclined readers will appreciate that the Sherwood is "fully
    spec'd." The 120-wpc power rating is with "all channels driven" into a
    specific impedance (8 ohms), over the full audio bandwidth and with a
    specified percentage of total harmonic distortion. With so many
    companies touting bogus specs (such as A/V receivers measured with just
    one channel driven into a 6-ohm load at 1 kHz with no THD given), it's
    refreshing to see it done right.
    Good specs are just the beginning. The Sherwood's build quality, design,
    features and audio performance are all well above what you might expect
    at its price point. This amp is a no-brainer recommendation for owners
    of the matching AVP-9080 processor, but there's no reason to stop there.
    Because similarly-powered competitors generally cost more and in some
    cases deliver less, anyone considering the purchase of a mid-priced,
    five-channel amp should audition the AM-9080.
    Features:
    **120 watts x 5 channels
    **modular construction
    **7-1/16 x 17-3/8 x 17-3/4 inches (HWD), 70.5 lbs
    Connectivity:
    **gold-plated RCA inputs (unbalanced)
    **five-way binding-post speaker terminals
    **Digi-Link jack for remote on/off with compatible products
    Look & feel:
    Weighing in at a hernia-inducing 70 pounds, the AM-9080 is
    built like a tank. The overall aspect is clean and attractive, with no
    external heatsinks to slice hands or collect dust. The silver-gray faceplate holds only a lighted standby indicator/button and a round power switch. The front panel has a brushed-aluminum surface, though if you're into hewn-from-solid-metal audio jewelry, this isn't the amp for you.
    The real beauty of this amp (indeed of any amp) is within its cabinet.
    This is a fully modular design, with each amp channel mounted on a
    separate vertical circuit board that plugs into a backplane (similar to
    the way expansion cards plug into a PC). Each channel has its own
    massive solid-aluminum heatsink. The only components shared between
    channels are three humongous power transformers. I've never before seen
    this premium construction method used on an amp at such a low price
    point.
    The rear panel is basic, with five gold-plated RCA inputs and five pairs
    of good-quality plastic binding posts. The power cord is permanently
    attached. A Digi-Link connector allows a compatible component such as
    the Sherwood Newcastle AVP-9080 processor to remotely switch the amp in
    and out of standby mode. This makes system operation no more difficult
    than with an A/V receiver.
    Performance: The AM-9080 has performed flawlessly during several months
    of almost continuous operation. Other than the clicking of a few
    protection relays during power-up, the amp produces no turn-on or
    turn-off thumps or noises. The unit stays relatively cool even after
    extended sessions of 5.1-channel mayhem. No fan is necessary unless
    you're going to enclose it in a tight cabinet.
    I've spent many happy hours listening to the AM-9080 in both two-channel
    music and 5.1-channel configurations using two very different sets of
    speakers. The preamp/processor in all cases was the matching Sherwood
    Newcastle AVP-9080. Initially, I used the amp to drive my long-term
    reference speaker complement, which consists of B&W Matrix 801 front L/R
    speakers, a Matrix HTM center speaker and a pair of Infinity Quadrapole
    surrounds. Because the B&Ws have plenty of low-frequency extension, I
    generally run them full-range. No subwoofer is necessary in my 12 x
    16-foot listening room.
    Although the Matrix 801s are a fairly benign 8-ohm load, they sound
    their best with an amp that generates plenty of current. They also
    require an amp with a high damping factor to firmly control the big
    12-inch woofers. The Sherwood took hold of the big B&Ws and never let
    go. Lows were solid and full, with plenty of punch. The all-important
    midrange was accurate and realistic, high frequencies clean and
    extended. I've had these speakers for close to eight years and have
    heard them with more amps than I care to count. The Sherwood, while not
    equal to the very best, is certainly right in there with the pack.
    I also used the AM-9080 to drive a complete set of Audience-series
    speakers from Dynaudio. At 4 ohms nominal impedance, these speakers are
    a bit tougher load for the partnering amp than the B&Ws. I spent some
    time listening to the floorstanding front L/R speakers as a full-range
    stereo pair, then added the powered sub to relieve the amp of bass
    duties.
    Once again, the AM-9080 proved equal to the task. I never felt the amp
    was getting in the way of this $4500 speaker package. In fact, the
    combination is beguiling, especially when good 5.1-channel soundtracks
    are played loudly in all their glory. There's no feeling that the amp is
    running out of steam even on the most dynamic peaks.
    Of course, audiophiles may prefer a bit more, shall we say, delicate
    touch for stereo music recordings. I won't try to snow you by
    rhapsodizing about the amp's magical ability to transport you to some
    sonic nirvana. At just $240 per channel, the AM-9080 is hardly going to
    cause Krell and Madrigal to lose any sleep. What you will hear is
    better-than-average solid-state sound, with plenty of grain-free detail,
    solid bass and reasonable soundstaging.
    There are a number of fine five-channel amps to choose from in the
    sub-$1500 price bracket, including models from Rotel, Parasound, Adcom
    and Marantz. The Sherwood's specs, design, build quality, styling, and
    performance are as good as -- if not better than -- these
    well-established brands. At $1200 list, the Sherwood Newcastle AM-9080
    is a stone-cold bargain.
    Rating: * * * *
    -- Lawrence E. Ullman
  8. Gil D
    Gil D Supporting Actor
    Mar 15, 1999
    577
    How does the Sherwood compare to the Anthem MCA5?
    I'ver heard that the Sherwood lacks dynamics and sounds a bit slow, whatever that means.
  9. Philip Hamm
    Jan 23, 1999
    6,873
    2
    In my experience the only thing the Sherwood lacks is a high price tag. [​IMG]
  10. Ricky T
    Oct 28, 1999
    921
    Jeff,
    Does this feature mean that an external DC trigger can turn the sherwood on and off. What are the compatible products?
    **Digi-Link jack for remote on/off with compatible products"
    Ricky
  11. Jeff Hipps
    Feb 2, 1999
    194
    An external DC trigger will not turn the AM-9080 on or off. Only Sherwood and Sherwood Newcastle models with our proprietary DigiLink III circuitry can do that.
    Jeff
