Sherbourn 7/2100 vs. ATI 2007 vs. Adcom GFA-7807 amps
Discussion in 'AV Receivers' started by MikeAF, Feb 11, 2004.
  1. MikeAF
    MikeAF Stunt Coordinator
    Jan 5, 2001
    168
    Hello all,
    I'm in the process of simplifying my system for my wife so I'm getting rid of my 2 and 6 channel amps and buying a 7 channel amp, now that there are some good ones out there. The Sherbourn 7/2100 has been at the top of my list for awhile but looking around today I found the ATI 2007 and the Adcom GFA-7807. All are in my price range, around $3000, and the same 200 watts per channel and all have balanced inputs. What I need are comments from owners of these amps about how cool they run, are they noisy, whether they are neutral, bright or warm, how long the power cords are and any other daily useage items I should consider that pictures and websites don't tell. I do have local dealers for all three but will probably not be able to audition them in my home before I buy. It will be mated with the Anthem AVM20 and Diva Swan speakers. The speakers tend to be on the warm side in my room and in my opinion, so I wouldn't want an amp which tends to be on the warm side in the chain. Any comments from owners would be greatly appreciated.
    Mike
  2. Allan*C
    Allan*C Agent
    Aug 17, 2003
    25
    Mike,
    I recently purchased a Sherbourn 7/2100 which replaced a Rotel 985MkII. It's connected to an Anthem AVM20. I'm not a big believer in amps making a huge difference, but FWIW I would say the Rotel was warmer. Others have posted Rotel deliberately rolls off the highs and I could probably say I agree in comparison to the Sherbourn. It runs cool and is quiet. I looked at, but did not try the Adcom and ATI. From what I've read, they are good amps. In the end I went by price. I got the Sherbourn at significantly less than I could find either of the other two. It was in the $1600 range if I recall. Overall very happy with it. It is heavy though as I believe the others are as well. Had the others been less I probably would have bought them.
  3. MikeAF
    Jan 5, 2001
    168
    Allen,
    Thanks for the info. The Sherbourn amps are the only ones I have had a chance to have in my previous system, the mono blocks, and was just curious how cool and quiet the new amps ran.
    Anyone else care to comment, and yes Iam reading the Adcom amp thread.
    Mike
  4. Chas_T
    Chas_T Supporting Actor
    Jun 1, 2002
    758
    Mike,
    I also own the 7-2100 Sherbourn mated with the AVM-20. The amp runs VERY cool and quiet. The only other amps I can compare it to are the Sherbourn 5/1500A, Modial/Aragon 8002, Parasound 855A and a Sony STR-DA777ES receiver. The Sherbourn for my ears sounds pretty neutral.
    When the 7/2100 was integrated in my system, I felt it had better soundstage and was a slight upgrade over the 5 channel model. I bought the 7 channel to passive bi-amp a pair of Paradigm Studio 100's, V2. My goal was to integrate seperate amps into one power source as rack space was/is limited. Another can of worms is using amps in mono blocks, 2 channel, 3 channel, etc. to power a 5.1, etc. system.
    I am not familar with the ATI or Adcom product line.
    Charles
  5. David_h
    David_h Auditioning
    Feb 11, 2004
    4
    My 7/2100 is my first separate amp. I have had it a few months now and can't imagine ever needing to upgrade. It sounds accurate and never gets too hot. I have a small computer fan in my rack that I used to turn on to help my old JVC reciever stay cool. I never use it anymore. The Sherbourn is terrific. I truley believe, one would have to spend thousands more to get anything much better.
    [​IMG]
  6. MikeAF
    Jan 5, 2001
    168
    Thanks guys for the replies. I know there were a lot of Sherbourn users out there.
    Charles and Allan:
    Are you using the balanced connections between the AVM20 and the Sherbourn or the RCA connections? Did you have trouble hooking the cables up as the inputs are on the bottom of the amp and the speaker connections are on the top which means I would have the cross a lot of cables. Was this a problem for either of you? Do you also trigger the amp on with the Anthem or just turn the amp on separately? Thanks again!
    Mike
  7. Chas_T
    Jun 1, 2002
    758
    Hey Mike,
    I am using balanced connections between the amp/ssp. However, I don't think the Sherbourn is a true balanced amp.
    I wrote this mail to Sherbourn on or about 2/3/03 about the 7/2100 being balanced and this is Mr. Tang's response.
    I did not have any problems connecting the cables, but as much as I tried to be organized, it's a bit of an pragmatic mess.
    Also Mike, I do not use a trigger. I am a manual kind of guy.
    Charles
  8. Allan*C
    Allan*C Agent
    Aug 17, 2003
    25
    Balanced connections yes
    No trouble hooking up cables, but a lot of wires!
    No trigger, just leave it on auto
  9. MikeAF
    Jan 5, 2001
    168
    Charles and Allan,
    Thanks for the replies.
    I'm still waiting for ATI users to chime in here.
    Mike
  10. David_h
    David_h Auditioning
    Feb 11, 2004
    4
    Mike,
    I am running the Sherbourn 7/2100 with a B&K ref50 pre/pro ans Paradigm ref studio 100s for mains, studio 20s for surrounds and the studio CC in the center. The paradigms are accurate and nutural withe this amp. The monoblocks run cool, I guess you could call it cool. My old JVC reciever used to get so hot you could fry chicken on it so I installed rack of 4, 3" cooling fans in my rack but have yet to turn it on sense I got the Sherbourn. I would highly recommend the 7/2100 to anyone.
    I listened to the Adcom and was going to buy it till the deal with the Sherbourn came along at $1900. I think it was worth every dime cause I will never need or want to upgrade.
    I hope this helps.
  11. MikeAF
    Jan 5, 2001
    168
    Thank you all for your comments and eventhough I still have to make the decision it's nice to have other's thoughts.
    Mike
