Jereme D
- Jan 29, 2002
I bought the X-1 a couple of months ago. It's all set up now. I ran Avia on it a couple of weeks ago. I could not get the sharpness pattern to look as they should, and the image in movies and on Xbox is not as sharp as I think it should be. There is no sharpness control for the progressive sources other than the ring on the projector. Is there something else I can do to make the image sharper? I built my own screen using some screen material I bought on eBay. Could that be a problem? I sit about 15 feet from the 80" screen if that makes a difference.
