Sharp XV-Z10000U projection distance?
Discussion in 'Displays' started by Richard Mass, Sep 15, 2003.
  1. Richard Mass
    Richard Mass Agent
    Jul 30, 2003
    39
    The sharp manual shows that the minimum projection distance for a 100" diagonal 16:9 screen is 13'2" and the maximum is 17'11". Is it best to be at one end of the range or the other or right in the middle?
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    It is better to be at/near the further end of the range than the close one. The reason.... the closer the projector is to the screen, the more noticeable the light from the bulb shining onto the centre of the screen is. The furtehr back the pj is, the more dispersed the light is all over the screen.
  3. Richard Mass
    Richard Mass Agent
    Jul 30, 2003
    39
    But what about your ability to still be able to zoom in or out or is that not important once you have your projector set up for your screen?
  4. David Giles
    David Giles Stunt Coordinator
    Mar 6, 2001
    138
    Richard,
    Once you have the projector mounted and zoomed correctly to fit your screen, you'll leave the zoom alone. UNLESS you plan on zooming in and out for different ratios (not all that common, but some people do it).
    David Giles
  5. DaViD Boulet
    DaViD Boulet Lead Actor
    Feb 24, 1999
    8,800
    3
    Richard,
    These folks speak the truth [​IMG]
    So...are you getting a Sharp 10000K? [​IMG] [​IMG] [​IMG]
    Do you already have your screen? This PJ looks AWESOME with a Firehawk.
  6. Richard Mass
    Richard Mass Agent
    Jul 30, 2003
    39
    Yes, I plan to get the XV-Z10000U. Now, I am just trying to decide whether to buy locally for the better service or to buy through AVScience, PlanetDTV, or IAVI and save on the unit, installation and sales tax.
    And yes, I am planning to go with a fixed 100" 16:9 Stewart Luxus Deluxe Screenwall with the Firehawk material.
    Thanks for everyone's help.
