Chip_G
- Dec 28, 2001
I figure the Subject of this thread will surely grab Gregg's attention. And since he did such an insane job calibrating my very uncalibrated 57xbr10w, I wanted to make sure he knew how much I appreciated him fitting me into his weekend down here in Mass. Gregg has already been established in the services he provides so I won't bother reiterating everything everyone has already posted about what he offers. What I will tell you is that you can add me to the long list of very satisified customers.
I don't know if it was a look of horror, or a look of "OH crap my $3000 greyscale analyzer must be out of whack!". But when we took the pre-calibration numbers, and I won the "OMG these are the worst numbers I have ever seen" award, I knew from that point on, today was going to be a good day. I have yet to scan in the actual graph so I can't show it to you yet, but I can tell you that pre-calibration, my numbers ranged from 4400K to 15,400K with nothing between 5000K-12,000K. Pretty freakin bad. However, post surgery they were all within 200K of 6500K.
The focusing adjustments yielded results that were typical of some one who knows what they are doing. And I use typical only because I don't have the capacity to explain in any sort of form to some one who hasn't had it done, would understand. To put it in the most visual terms I can....along with the convergence and the geometry, white letters on the screen no longer have a blue halo around them...!!?!?!!
Oh yes, the glare screen. Like most every other first time RPTV owner, some one suggesting to you that you need to remove the protective screen is for the most part, a hard thing to believe. The best analogy I can come up with is comparing it to a pro hockey skater. Name one pro hockey skater that wears a full face shield? None right? Why? Because not only do they have the tendancy to distort images, but they also create so much glare from rink lights, that any time the puck leaves the ice, you'd be looking through a criss-cross pattern of plastic while battling tiny versions of the sun. Well, ok, so it takes away glare and makes the image more life like, it's probably called a protective screen for a reason, no? Back to the hockey helmet analogy... You just have to become more aware of what you let near the screen/your face. If this isn't something you think you can control because of pets, kids, clumsy friends, then maybe removing it isn't the best choice. But, I have included two links below which are the before and after pictures of my TV with the glare screen on and off. When Gregg suggests to you to remove the screen, do so.
Well, I'm pretty tired of typing and I'm sure you're pretty tired of reading. But you can chalk me up as another very happy customer of Gregg's. He's a great guy, very knowledgable and if he would just stop being a canadian hockey fan, he might just be OK.
Chip-
the before and after (nevermind the way my plants look in the after, there's like a 5 month difference and I can't keep them alive):
Link Removed
Link Removed
Chip-
Link Removed
Link Removed
