Setup Questions with Denon
Discussion in 'Archived Threads 2001-2004' started by Cyrus_I, Nov 2, 2002.
  1. Cyrus_I
    Cyrus_I Stunt Coordinator
    Aug 20, 2002
    58
    I have just a couple of questions on the set up of the Denon 1603. When I want to use my VCR the tv only recieves the image on channel 3 and not in "Video". How do I change this. Also what does the "punch through" function do with the remote.
    Cheers
  2. Cyrus_I
    Aug 20, 2002
    58
    Does anyone know if the 1603 has component switching as well?
  3. Jeff Braddock
    Jeff Braddock Second Unit
    Jan 26, 2002
    306
    Cyrus,
    According to Denon's website , it says it does component switching, 2 in and 1 out.
  4. Chuck Kent
    Chuck Kent Supporting Actor
    May 29, 1999
    983
    Cyrus: Does your TV have video inputs other than the channel 3 r.f. connection? If it does, what brand is it? Different brands use different ways to determine how you get switched to these other inputs. If your TV doesn't have other video inputs, then you need an r.f. modulator that will allow you to use composite connections into the r.f. input. (R.f. modulators are widely available at Radio Shack, many home improvement centers and even at places like Circuit City.)
    Punch through refers to the remote's ability to control the receiver's volume while in a different control mode (say CD or DVD.) Punch through can also refer to controlling the TV's volume if that is what you want in lieu of the receiver's.
