Settings for Philips 4:3
Discussion in 'Displays' started by Shanil, Sep 28, 2003.
  1. Shanil
    Shanil Extra
    Dec 6, 2002
    19
    I have a 29" philips 4:3 TV. It has 4:3 expand but does not have 16:9 compress. Should I set my dvd player to 16:9 or 4:3, or can the set be adjusted to the squeeze mode? I know how to get into the service menu, but have no clue what's going on in there.
    According to the philips web site, this set is supposed to have a 16:9 compress mode, but it is not in the menu or the manual.
    http://www.consumer.philips.com/glob...d=29PT2252_79R
  2. Shanil
    Shanil Extra
    Dec 6, 2002
    19
    Bump [​IMG]
  3. ChrisMatson
    ChrisMatson Cinematographer
    Dec 14, 2000
    2,181
    110
    Your link doesn't work. If you can't access it via the normal user menu, I can't help you. Setting both the TV and DVD player to 4:3 (4:3 letterbox on DVD menu) should yield a normal image without distortion.
  4. TimG
    TimG Second Unit
    Oct 5, 1999
    361
    Why would a 4:3 tv have a 4:3 expand on it?
    TimG
