Setting up the delay from front to rear...
Discussion in 'Archived Threads 2001-2004' started by Brad Craig, Feb 18, 2002.
  1. Brad Craig
    Brad Craig Stunt Coordinator
    Feb 1, 2002
    58
    I was reading on a site (that I have since lost) on how to configure the delay of sound when going from front to rear >>> like for example if a plane in a movie was flying overhead...
    Does anyone have a formula they use for setting this up on your receiver???
  2. Jerry Wright
    Jerry Wright Agent
    Feb 15, 2002
    44
    Brad, If your receiver/amp is similar to mine, here's how I did it. It's really built in. scroll through your setup system on your rec. you should see fronts, center, and surrounds with a number next to them. You put in the distance each is from the main listening area and the receiver does the delay configuration for you. Good luck!
    Jerry
  3. Bill Kane
    Bill Kane Screenwriter
    Feb 5, 2001
    1,359
    Brad: Man, you're on a fast learning curve here on the forum [​IMG]
    This can be complex. Some receivers allow you to set surround speaker delays using feet distance, which translates to the proper millisecond (ms) delay. Others like my Yamaha offer only center channel delay for DD/DTS playback (plus a more complicated rear spkr delay for individual DSP modes -- right now I'm leaving factory presets).
    To give you an idea, here's a thread on this featuring sound guru Guy Kuo click here
