Setting up Speakers (1 Viewer)
Morgan
What's the name and model number of the level meter you buy at Radio Shack? I've read here before that's it's quite helpful in fine tuning your speakers. Also, what else can you use to set up a home theater system? Is there a calibration DVD you can buy that helps in getting the best sound from your system? If so, where can you get them?
Thanks.
Tony.
Vlad D
Vladimir Derenoncourt
Analog-Display Sound-Level Meter
Part #330-2050
$39.00
Here is a link to it on Radio Shacks online product catalog. Here
There are 2 (actually there is a 3rd but I can't remember the name) calibration DVD's. AVIA and Video Essentials.
You should be able to find them online.
Oren
There is also a digital version of the sound meter, which I prefer.
Frank Zimkas
The "Sound & Vision Magazine Home Theater Tune-up" DVD was $19.95 at MediaPlay when I bought mine.
