Jerry Roberts
- Oct 15, 2002
I recently purchased a Sony STR-DE885, and am having some real problems in determining how to set this piece of equipment up properly. The manual seems to be written at a level that if you understood it, you wouldn't need it in the first place. An example is selecting crossover frequencies...although I know what a crossover frequency normally implies, where do I find the correct value to enter into the system? They recommend "changing" the LFE cut off frequency, but give no inclination as to what or why!
I've been unable to get a grasp on the "why's" of what I'm trying to do, and as a result, after I select my sound source, I just end up pushing buttons until I get something that sounds pretty good...definitely not the way it should be done!
Last night I had a movie on DirecTV that was broadcast in Dolby 5.1 - I can't even figure out how to set my receive up to properly play that, or what lights should be lit on the front panel to indicate that everything is working right! (BTW I'm using an optical audio cable between the Satellite receiver which is 5.1 capable and the HT system).
Is there someone out there that can help me cut through the confusion of the Sony Operators Manual, and get my HT system operating the way it was designed to operate?
