Dave Koch
- May 13, 1999
Hi:
Just stepped up from a Pioneer 909 (I think- LD/DVD combo, first generation) to the DV-45A. I auditioned a couple others- Denon 1600, Panosonic 82- but liked this one the best. Anyway, there have been a LOT of changes in DVD players, and I am not all that sure about set-up anymore.
I guess I should also say this goes into a Marantz AV 9000, and then to a Rotel 1095.
OK, so, first, do I let the DVD decode DTS/DD, or do that coax or toslink? I guess the deciding factor here is what is a better decoder, the Marantz, or the three burr-browns in the pionerr. Opinions?
With the DVD-A and SACD, I have no choice- that HAS to go into the ext decode input, and the 6-Channel Direct out. Is this correct?
OK, now this I do not understand: the setting speaker distances (delay) and levels in the DVD player. Should I level those alone anbd zeroed, as the Marantz has all that processing in the preamp, and it is all set up with VE? Or, since SACD/DVD-A goes through the "direct" mode, does it HAVE to be re-set up in the DVD? If that is set up in DVD, will it effect all output, or only the decoded audio? (That is, if it effects the DD/DTS, would that get double processed in the marantz later???) (Does that make sense????)
On a similar note, do I want to muck with the video adjustments in the DVD, or do it all on the TV? (BTW, I did muck with the sharpness, turned that all down...)
Anything else I need to know?
Thanks!
dave
Thanks!
dave
