Steve Won
- Dec 7, 2000
I've got a Denon 1801 receiver with a Denon DCM 370 CD Changer which I would like to set up as a 2 channel stereo system.
I've got a couple of Acoustic Research M1 bookshelf speakers which will do for now with a PSB 8" sub.
I'm not sure if I should set up this sub similar to a 5.1 config with the sub plugged into the sub output of the receiver or if that output would only be used when there is a Dolby Digital or DTS signal and would be totally bypassed with the stereo set up.
Or should I pass the L & R outputs from the receiver to the sub and then connect the speakers to the sub as the sub has the connectors for this config. I assume with this config, I should set up the speakers as large and let the sub manage the signal it passes to the speakers.
Thanks.
Thanks.
