MikeGee
- Dec 11, 2004
I'm wondering if anyone here tweaks their Pioneer 1014 or any other receiver by ear?
I let the automatic MCACC do its thing and finished watching a movie and it seemed to be way off as far as making transitions from sound passing from the front to rear channels.
How i adjust my settings on mine is i go into the manual MCACC menu and for Speaker distance i go through each speaker and it will continuously play a test tone.. What i do then is play around with the settings.. say i'm doing the front right speaker.. i close my eyes while adjusting the distance (on the remote) until i get a sound that sounds exactly where the speaker is...
The problem i find is that the MCACC doesnt do this at all accuratly.. i'm not sure if this is how its supposed to be done i'm kinda curious if anyone else uses a similar method or thinks i'm nuts... Cause i rewatched certain scenes in the movie and now the transitions seem dead on.
The test film was X-men 2
