Setting Overscan on Toshiba 55HX70 with HPOS & VPOS
Discussion in 'Archived Threads 2001-2004' started by Scott_R, Oct 9, 2001.
  1. Scott_R
    Scott_R Auditioning
    Jun 29, 2000
    12
    I need to adjust some overscan on my set and have adjusted the HIT and WID but the picture still needs to be moved a little to the left to be centered according to AVIA for 5%. I've been scared to use the HPOS and VPOS since I've read in a few different places that on this set you can mess up your S-video inputs. Does anybody know the best way to do this and if this is indeed the case.
  2. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    HPOS is harmless. VPOS is the one to worry about. If you absolutely must change it, disconnect all inputs to the TV first.
    John Golitsis
    Next Big Thing Electronics
  3. Scott_R
    Scott_R Auditioning
    Jun 29, 2000
    12
    Thats good then because the HPOS is the one thats off. It only needs to move a little to the left. I'll try it tonight and see what happens.
    I still would like to know why the VPOS is bad with inputs hooked up. Does it just affect these sets?
  4. errol
    errol Stunt Coordinator
    Dec 29, 1999
    150
