Scot Pritchard
- Mar 6, 2002
I have a b&k ref 30 preamp and a svs 20-39cs sub wwould it be better to use the ref 30 pink noise or the ve disc to set the sub? the reason i ask is because i had it set up using the ref 30 but tried the video essentials disc just before and their was a differance between them with the ref 30 the sub level was at +4 and with the disc it dropped to --7. with the ref 30 the pink noise is already at a certain level when you begin. with the ve disc i set the volume to 0db to level with method would be more accurate.
