Set up for projector
Discussion in 'Home Theater Projects' started by Theron Renfro, Jun 6, 2003.
  1. Theron Renfro
    Feb 3, 2002
    15
    I am going to be building a home in the next few months. I have already decided to have it pre-wired for my theater. Right now I have a 47 widescreen rear projection tv. Eventually I will be getting a projector and screen. Can someone let me know what type of connections I should have put in the ceiling. I guess it will also need a standard electrical outlet in the ceiling. Is this correct. Any other insights on what to make sure is prewired in the room will be helpful and appreciated.
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    Run a conduit (PVC @ 2" is fairly good) so that you can run your video wires through it. If you run string at the same time, this will allow you to pull cables if the need arises.
    Just an FYI.
